Notices
Figure this one out.
Old 09-13-2009, 06:24 AM
oldairboater's Avatar
oldairboater
oldairboater is offline
Like everyone else I would suspect the speed sensor. Had one go bad before and it messes with the bike big time.
Old 09-13-2009, 07:34 AM
cHarley's Avatar
cHarley
cHarley is offline
Forget about the turn signals for now and focus on the VSS which is likely causing the speedo problem. Timing for the turn signal auto shutoff function is based on several things, one of which is the vehicles speed as determined from the VSS. Fix the VSS problem, and I'll bet your turn signal issues go away.
Old 09-13-2009, 08:02 AM
Splatter's Avatar
Splatter
Splatter is offline
Originally Posted by DWG05
[...] Came to a stop sign with my signal on, pulled the clutch in, and the motor dies. Starts right up, won't idle but will run at RPM, make the turn, and the speedo is still dead, no miles being registered, plus the turn signal won't self cancel. [...] What the heck could these four things have in common. [...]
Three of the four:
1. Speedo needs the speed sensor for obvious reasons.
2. Odo need the speed sensor because its driven by counting the pulses from the speed sensor.
3. Turn signal self-cancel mechanism uses the speed sensor and an inclinometer to decide to self cancel. (That's why they won't cancel while you're sitting at a stop light, but will eventually cancel if you accidentally turn one on while driving straight.)
4... dunno why it would die at idle w/no speed sensor.
Old 09-13-2009, 08:33 AM
blkfalc4's Avatar
blkfalc4
blkfalc4 is offline
Cycle the hell out of the ignition switch and see if it changes anything.
Have had to take mine apart and clean it before to fix same symptoms.
Mike
Old 09-13-2009, 09:16 AM
schumacher's Avatar
schumacher
schumacher is offline
real men don't need speedometers
Old 09-13-2009, 01:02 PM
WRAITH's Avatar
WRAITH
WRAITH is offline
Check the connector plug, sometimes they get water trapped inside (from pressure washing).
02RKC
05-17-2011 09:51 AM
ictdog
02-27-2009 12:38 PM
lilfroger
02-20-2009 09:35 AM
Indianspringsaz
04-05-2007 09:40 AM
vicdal
06-29-2006 03:51 PM
Quick Reply: Figure this one out.
