What is the best 6 speed option???
Ok guys and gals, I am interested in doing a 6 speed upgrade to my 06 Deluxe but there are plenty of options out there. I am sure some are far better than most, and I do not want cheap junk. So what are the best options out there to do this upgrade? I was thinking about just buying the complete SE 6 speed, but it is not cheap at all. So I just wanted to be able to consider all of the options. I am very open to suggestions! I plan to upgrade the bike to a 103 big bore and 6 speed at the same time. So it will be torn completely down. So just about any option should be doable.
Thanks tons!
Brian
Thanks tons!
Brian
There are many different options out there and im sure within a couple days you will have 50 posts on the subject.
I run an Ultima 6 speed and i have installed many of them. In my opinion they are the best bang for the buck as far as the lower priced 6 speeds go. I run the dog s**t outa my bike (99 dyna) and have never had one single problem with it.
Now with having said that if i had my choice of 6 speed where money wasnt an issue i would get an S+S 6 speed tranny. I installed one in my buddies bike and you can definately tell the difference between his $2k tranny and my $800 tranny. The difference in shift feel is amazing.
The Ultima trannys will more than handle the power of mildly modifies bikes. If you plan on going for over 100hp then i would highly suggest the more expensive trannys
As far as the more expensive trannys for higher hp bikes its all a matter of opinion. They are all good trannys with really no problems. S+S, Baker, SE, Jims. Theyll all handle the power so it all comes down to what kind of deal you can get on it, and what manufacturer you prefer. Some require minor modifications to the tranny case which can easily be done with a dremel or grinding bit on an air tool.
Good luck, and happy riding
I have found a few decent deals on the SE 6 speed gear sets, but was a little concerned about the modifications needed. I have seen what has to be done, and I guess unless you intend to go back to the stock setup (not likely) the mod should not be THAT big of a deal. My best friend is a harley shop foman, so he knows how to do all of this stuff. So that is for sure an option. I have seen the cheaper trannys and could not help but think you get what you pay for. It seems that is likely true for the higher HP engines.
Thanks again guys!
Brian
Thanks again guys!
Brian
