Warped Rotors on 09 RKC
Took my bike in yesterday to the local Indy for my 5000 mile service(6280 actual miles)and found out that the front rotor is warped and the rear is slightly warped. Has anyone had this situation so early? Did/will HD warranty cover replacement of the rotors?
When I changed the rear brake pads a few years ago I had to add a shim between the rotor and the rear wheel hub...The problem was the inside pad was constantly rubbing on the rear brake rotor and causing a slight squeal...The calipers are supposed to "float" in terms of keeping the brake pads aligned with the rotor. Sometimes moisture can get into the caliper bolts and cause corrsion that keeps the caliper from floating to adjust for pad wear. Has your bike been in any heavy rain or moisture?
So far as warranty I'd say you should be in the clear but I'm not the service manager....Go to your dealer and see what is what!
