Tight allen heads, phillips screws, try this
I like to use one of those phillips head drivers that you hit on the end with a hammer which then turns the screw a little. Sometimes if you try to turn a screw by brute force the head can shear off. By shocking it with this type of impact driver, it will break it loose instead of breaking the head off.
OK I read this post yesterday and thought Yeah right. Today Im out in the garage with my carb on the bench and Im trying to get the float bowl screws out. Im trying real hard and they won't budge. I look up and there on the bench is my cordless drill. So I grab it and set the clutch about half way with a Phillips bit. Low and behold they come right out after a little impact action. Great tip thank you very much.
