burnt clutch or ok ?
I was acting dumb and did 1 burn out at a party and my clutch went from engageing off the handle and fine. To all the way out and was slipping bad I adjusted it and no more slipping I can feel but still engages way out on the handle. Have tryed to adjust again no luck. Would a new clutch be my best bet or just live with it cause its not sliping anymore 2008 lowrider very pissed that one burn out did this.
1 burnout should burn up your clutch, unless you feathered it too much and/or rode the clutch... What does the primary fluid smell like?? Does it smell like normal oil or does it smell burnt? Have you tried adjusting the clutch at the primary (or just at the cable)??
oil was fine to me adjusted both cable and adjuster screw in primary several times to try to get it the way it was but it still engages more then half way out on the handle but it seem to engage fully with no sliping really opened it up and it seemed ok would just like the old feel that it had back
I am looking for the answer too as mine seems to jump upto 4000 rpm in 4th quicker than the ground speed I think should be....been this way since I got it. every other gear works fine, no slip feel. It just dont seem to be pulling right to me until the wheels catch up with the engine. I dont ever smell anything funny either. But never smelled the primary stuff. Hell I dont know if my 84 has a wet clutch or not. Has a cable , I know that much.
i think your 84 is a wet clutch but if you dont know that tells me you might need to check under the primary cover if it is wet then you should change your primary fluid i change mine about every 5000 miles thta might help your slip in foruth but if its just in 4th gear id be more worried about your gear box maybe there a ground spot in your trans gear and it hit it and slipes for a second
another guy locally thinks it is just the toque curve of the screaming eagle cams....still not sure. That sounds reversed to me, usually when you hit the torque area, the engine revs quicker, not slower.
old skool1983
04-17-2009 02:31 PM
