Helmet Question
So I was walking along my driveway after riding and I was carrying my helmet with me at my side when I accidentaly dropped it. Is the helemt still good?
I've been reading conflicting reports where it says if you drop your helmet from a low height that that helmet is still usuable but then I read other reports that state once you drop your helmet you have to replace it.
So I'm a little torn. Helmets are expensive (I wear a FF scorpion EXO-700) so I can't exactly afford a new helmet everytime one gets dropped and I have a hard time beleiving that a helmt would be rendered useless after a short drop.
Anyone have any thoughts?
I'm not an expert but I would say that your helmet is ok. It's most likely that you've only scratched or chipped the finish. I did that once and after changing bikes, I had it repainted. In 35 years of riding, I've never heard what you said about the recommendation to replace your helmet if you drop it.
It's designed for one drop.
Sorry....you need a new helmet.
Or, rather....what's YOUR head worth? It has already taken it's one compression......might as well not even wear one then, IMHO.
If it were me, I'd get a new helmet.....and hold on to it better next time!![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
~Joe
~Joe
I've always heard that the exact point where the helmet made impact is compromised... enough to warrant a new helmet is your call.
What are the chances you will hit that same exact point while wearing the helmet in the event of a crash...
![Icon Nut](https://www.hdforums.com/forum/images/smilies/icon_nut.gif)
Agreed if it cant take a small drop how is it going to protect you? I do know that back in the day that they would take a pretty good beating and still work
If it's not cracked,I would'nt worry about it ,unless you had a bowling ball in it when you dropped it ,something has to be on the inside to compress the padding from a short fall. IMO. But it's your noggin.
