Kuryakyn Informer
Kuryakyn Informer
Anybody running one of these and have problem with it recalibrating back to empty at dusk, low light and shadows from trees as you go buy. Tried to tape over the sensor and leave it that way, but that didn't work either. Each time I calibrate it back, I get the cal sweep and works fine in daylight for months, or darkness, but goes nuts at dusk, especially below 1/2 tank. Anybody find the secret to make it stable at low light conditions?
Ron
Ron
Yes I did. They said if it was under two years old they would swap it out. That really surprised me. That's fine and dandy but I've hear of other people having this problem too, so before I go through what might be a useless exercise I thought I'd ask if someone might have a way around this probably designed in quirk. Exchange will be my last option, depending on feedback from users.
Ron
Ron
I had the same problem with mine that I put on about a year ago. I called Kury and they sent me a replacement no problem. Great customer service. From reading the new instructions and the old ones I think they changed the programing of it for that problem but tech support said they didnt know of any problem. Anyway, with the new one it will only reset when the tank is reads about 1/3 or less and only within the first two minutes of recieving power. No prolems since and I constantly ride during pinky time through trees in the same places that used to reset my old one.
Looks to be a relatively expensive LED fuel gauge ....... Hmmmm, $125 vs. resetting the odometer at fill up ....... then again, to each his own, I don't have authority to judge. However, when I become king of the world, some of this sh$t is going to change!
Ron
toecat2000
09-21-2016 04:32 AM
