Talk me out of a SE 113?
Here's the deal I'm contemplating:
08 Fatbob -
SE 113 kit with MVA heads
http://www.harley-davidson.com/en_US...ng/US_SE_P.pdf pg 23
Pro Kit race clutch
Automatic compression releases
The dealer told me 08 Dynas already has the upgraded bottom end, oil pump, and roller bearing.
All this for around 5K parts and labor....give or take a few hundred. I keep my warranty, get 125/120 power...
Am I missing anything?
08 Fatbob -
Pro Kit race clutch
U mean the dealer said the stock 08's bottom end are different from the 07's?
I have a buddy with a 09 S/G he had the dealer do the 113 before he picked it up, this thing is BADD and covered under factory warrenty since it was done in the first 1k miles and done at the dealer. D&D pipe and programmer were all done. Added about 4k to the price....
I have built several 113's and no top end leaks. I would re-consider buying the HD kit. It will provide much more power than stock, you can expect more using differnt cam/head combination. The ones I built made 120 horse and 133 pounds foot of torque. Use the psiton cylinder kit, send the crank to Darkhorse for rework. This is a priority. If this step is not done, bottom end will come apart. Either for crank repair/replacement, or it will do it itself. Send the stock heads to T-Man and run his 590 cam. New oil pump chain drive and support plate are fine. SERT with 53 HP Inc T-body. A.I.M. clutch lockup with SE clutch spring.
kingkingking
03-02-2012 06:40 PM
