WOODS cams and NOISE
Old 07-23-2009, 02:03 PM
chad pickens's Avatar
chad pickens
chad pickens is offline
Default WOODS cams and NOISE
I installed some woods Tw/9b cams in my 06 n/t .I have what almost sounds like a bottom end knock bit its from the valve train! I have looked everything over several times and see nothing wrong .Ive heard that his cams are noisey and hard on the valvetrain but i didnt expect it to sound like this.Am I missing something or is this normal?
Old 07-23-2009, 02:54 PM
trippy57's Avatar
trippy57
trippy57 is offline
Not sure if this will help, but when you set the valve clearance were you sure you were at top dead center?
Old 07-23-2009, 05:08 PM
FastHarley's Avatar
FastHarley
FastHarley is offline
Former Sponsor
Of course they are built radical. For every gain, there is a compromise. If you wanted something more road friendly you may chose a different profile or manufacturer.
Old 07-23-2009, 05:30 PM
chad pickens
Road friendly? the power is fine but its very loud when the bike is out by the garage 100 ft away i can hear the knocking Is that normal for these cams?
Mchad (07-05-2023)
Old 07-23-2009, 05:50 PM
99 Conv's Avatar
99 Conv
99 Conv is offline
I did not look up the cam you installed for specs, but if this is a large lift cam you May have the lifter roller hitting the lifter Block slightly when it's up..Just a thought
RoadKingRon1's Avatar
RoadKingRon1
RoadKingRon1 is offline
I don't know much about Wood's cams but it shows .630 lift and 252 duration. A little radical but not that bad. I use Mackie cams .596 lift and .238 duration and I have no noise.
How long have they been in? Gear drive or chain?
This would worry me because their website recommends 10.5 minimum compression ratio. I'm assuming you're running stock pistons because you didn't mention pistons.
Adjustable pushrods striking the tubes? Really not enough info. Have you called Wood's?
Old 07-23-2009, 06:04 PM
chad pickens
Ported and milled 110 heads 95 inches comp 10.8-1. andrews pushrods. roller rockers .Lift with rockers 650. correct sorings for cam tp rocker boxes chain drive andrews cam gear what else would you like to know
Old 07-23-2009, 06:17 PM
RoadKingRon1
what is causing the noise?
Wow, you did a real build. Piston/valve interference? Have you called Wood's?
Old 07-23-2009, 06:23 PM
chad pickens
talked to woods he was at a loss also . it sounds like the valve train area. but the sound is like a rod bearing in a car engine. the piston to valve clearance is very large. Should the rockers have any side to side movement?
Old 07-23-2009, 06:37 PM
forever unfinished's Avatar
forever unfinished
forever unfinished is offline
First question I would ask is did you ensure you had enough clearance for the cams to the case ? As well as did it start making the noise the first time you fired it up or recently since build? And did you do the work your self or have it done at shop etc.
Quick Reply: WOODS cams and NOISE
