Can you adjust a bike to run any hotter or cooler when you program the SERT on a touring bike? I'm trying to figure if getting a stage 1 and a SERT done to my bike will help out with the running to warm problems or not.
If you are running too lean you will run hot. The SERT allows you to adjust AFR. Just got mine. Trying to read up a bit before I play around with the maps to much.
