hot weater tire pressure ?
Old 07-20-2009, 05:39 PM
cHarley's Avatar
cHarley
cHarley is offline
Originally Posted by fastbagger
Gigg stop at Durango HD. They have a machine that removes the air from your tires and replaces with nitrogen. I did that in my '09 FLHX as was concerned of the hot AZ weather. $15/tire and takes 10 minutes. Nitrogen does not change PSI like regular air. Well worh it.
There's a sucker born every minute.......
Only use HD certified air or you will void your warranty.
Available in a 4 season variety pack.
Old 07-20-2009, 06:15 PM
confederate's Avatar
confederate
confederate is offline
Most Wanted
I recommend checking what the tire states on the sidewall. It has a max rating when checked cold. I run about 3 lbs. under that rating on both tires.
Old 07-20-2009, 11:58 PM
fastbagger's Avatar
fastbagger
fastbagger is offline
cHarley the dealer was all out of that HD certified air that's the reason I went there. So I decided to use the nitrogen instead. Besides 4000 miles in 13 days on my road trip I did not want to take chances.
BFalvey
03-18-2014 06:44 PM
RaceFace
06-30-2013 04:35 PM
Charlie Fogg
07-28-2012 07:22 PM
FenderGuy53
08-01-2011 01:30 PM
huskers11
09-24-2007 06:37 PM
Quick Reply: hot weater tire pressure ?
