Tip needed about throttle cables.
Old 07-19-2009 | 06:23 PM
traveler's Avatar
traveler
If my cables still operate smoothly, then how do I know when to lube them?
Old 07-19-2009 | 08:50 PM
tinman67's Avatar
tinman67
white silicone grease. It is good for displacement of water and will last waaayy longer than WD-40. Same lube recommended for e-brake cable on cars.
Old 07-20-2009 | 07:11 AM
1flhtk4me's Avatar
1flhtk4me
At each service interval,5000 miles.
Old 07-20-2009 | 07:58 AM
Da Gumpmeister's Avatar
Da Gumpmeister
HUH ????? When did you move, Joe ?????? OR did I miss a post along the way ????
Guess the "Hills" you were in, were NOT where THEY wanted you to be. Keep your head down, Sir.
Old 07-20-2009 | 08:15 AM
carpetride's Avatar
carpetride
I use 3 in1 oil and a syringe.
It lubricates nicely and also makes for a good skin lotion and dessert topping.
Old 07-20-2009 | 09:44 AM
traveler's Avatar
traveler
I've tried that little aluminum tool that clamps on the top so you can spray the lube in....didn't work worth a damn.
~Joe
Old 07-20-2009 | 09:52 AM
harleydavis's Avatar
harleydavis
~Joe
+1......quit using the tool as I found it useless, as well.
lp77
07-03-2013 05:24 AM
paulies 07
08-04-2011 09:29 AM
orcas tow
08-31-2008 06:41 AM
ggibson
06-02-2008 04:56 AM
HDF Tech
09-16-2005 05:46 PM
Quick Reply: Tip needed about throttle cables.
