How often are you adding oil?
Old 05-23-2006, 07:52 PM
whaap's Avatar
whaap
whaap is offline
Default RE: How often are you adding oil?
05 1200 C I bought used a month ago with 1300 miles on it. Now have 4500 miles and I've used perhaps 1/4 quart.
Old 05-23-2006, 07:54 PM
skos's Avatar
skos
skos is offline
I have about 3K on mine. Had to add a Qtr about 1 month after dealer did a change so thinking the dealer shorted me. Since the add I have not used any!
Old 05-23-2006, 09:14 PM
71tradewind's Avatar
71tradewind
71tradewind is offline
On top of mechanical condition of your bike,your riding habits can affect your oil consumption.I smack mine in the a$$ from time to time so I burn more than I would if I were riding like a geezer.[sm=gears.gif]
Old 05-23-2006, 09:44 PM
bay13's Avatar
bay13
bay13 is offline
I've about 2100 and have not had to add any oil, I check it everytime I stop for gas(it's hot them). One oil change so far at 1000 miles. Will change to Redline 20w60 at the 3000 mile mark.
Old 05-23-2006, 10:03 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Never had to add oil between changes.
Old 05-23-2006, 10:04 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
ORIGINAL: skos
You got shorted........IMO[:@]
Old 05-23-2006, 10:29 PM
springerGT's Avatar
springerGT
springerGT is offline
I wouldn't even check it.The first oil change is on them. Let them do it. It is new.
Old 05-24-2006, 02:20 AM
IRready's Avatar
IRready
IRready is offline
Should not use any oil between oil changes. I recommend checking regardless. Mine had the bad valve stem seals and used a qt every 1500 miles. Had them replaced under waranty, now it uses none. HD will tell you using some is OK, using none is OK IMO.
Old 05-24-2006, 02:25 AM
Johnny's Avatar
Johnny
Johnny is offline
Typically after every long ride
Old 05-24-2006, 10:30 AM
bensonjv's Avatar
bensonjv
bensonjv is offline
Supposed to be checking my oil? Crap.....be right back.
Quick Reply: How often are you adding oil?
