heel toe shifter bolt torque spec?????
i have a touring manual and couldnt find anything on the heel toe shifter. i was going to try and tighten the bolt to the correct torque spec, but couldnt find it. does anyone know what it is. any help would be great. thanks.
take it off and throw it in the trash
I only know one person that uses it and he just added little blue loctite and gave it a good turn, been good ever since.
btw he lost 2 before this lol
until it stops rattling. Just pulled heel shifter yesterday and cleaned up the splines, blue loctited it, and got it as tight as I could. It doesn't rattle now and won't fall off like it tried last week... at least for another year I hope.
Take the time to clean the shift arm and the shaft splines with brake cleaner.
A thin film of oil or grease in there will prevent a nice tight fit.
As has been said, use blue loctite and torque to specs.
I appreciate everyones input. In the past 2.5 years since i bought the bike, i have lost the entire shaft and shift levers and almost lost another complete set up. I took the toe shifter off and noticed the shaft spline was slightly worn which is why the toe shift lever was loose. i thought it was the splines on the shift lever. i tighted it down after i put the lever in the vice and tried to close the gap a little. Im sure im going to have problems with it again. i have a trip on the 27th to CA that im hoping does without a hitch. thanks again for the help. Ride Safe.
