Problem with low miles???
I am looking at buying a used motorcycle. It is a 2001 Harley Electra Glide with only 6,800 miles.
Is there any reason for me to be concerned about the low miles?
I would think that would be a good thing seeing as it is practically brand new...
Thanks
Thanks
hey devildog, a bike like that may have a tendency to turn into all the local watering holes or Dairy Queens, and some have been known to quit at the city limit sign. With patience and practice I believe this behavior can be corrected. Good luck.
The big risk is that it becomes "Garage Candy". That's a condition that the owner wants to go for a ride but instead just calls his friends to see if they want to come over and see it.
Seriously, there are a lot of low milage bikes out there for a lot of different reasons. A low milage bike or any used bike requires due diligence on the part of the buyer.
Gaskets, seals and hoses can be dried up due to non-use.
Start the bike and look for leaks or seepage.
It really depends on if the bike was ridden regulary for short distances, or sat for a long time without being run.
Buy it and ride it if it is what you want at a price that suits you. It will be fine. All of this worry over dried up seals, gaskets, and hoses is being overstated. It will be fine. So what if a gasket leaks?...replace it and ride on.
My '77 Ironhead had 11k miles on it when I bought it in 1992. Even for an Iron, it didn't leak like a sieve from sitting. My 1990 Mustang only has 41k miles and hasn't had an average of 200 miles a year put on it over the past 15 years. It doesn't leak. Our '77 Ford pickup has less than 50k miles on it and only gets driven a few hundred miles a year. It ain't a leaker either. I bought a '87 Mercedes last year that had only been driven 600 miles in 9 years. Since then, I've put 7k miles on it. It hasn't sprung a leak, yet.
