Brake lights
Brake lights
On my previous bike (Roadstar), I installed a box that made the brake lights flash several times then stay on for a few seconds then start all over again. What can I buy to make the lights on my Roadglide do the same? Also I would like to have my headlights pulsate. Is there a add on for this? Do the dual lights cause an installation problem? Thanks, Mike
Kurykyn and the moco (and others) make a module that will give you running lights and brake thru your turn signals. Each is a simple mplug and play install. The Kury unit gives three initial flashes to the brake light when you stop-very visible.
Headlight modulators are avaiable from a number of sources-try kisantech.com
I use the "BACK OFF" brake module.
I have it set to flash five times quickly then burn steady.
Mine is the XP Model
LINK to their stie:
http://www.customdynamics.com/signal..._modulator.htm
LINK to their stie:
Ram
10-26-2005 10:37 PM
