T/C 88-A in a softail?
Old 07-03-2009 | 07:40 PM
chad pickens's Avatar
chad pickens
Default T/C 88-A in a softail?
Is it possible to put the T/C-a motor in a softail ?
Old 07-03-2009 | 09:15 PM
will2002's Avatar
will2002
Anything is possible, but I think it would be a LOT of work!
Old 07-03-2009 | 10:15 PM
skratch's Avatar
skratch
i think if the mounts work, then you would end up with an extremely vibey bike. the a engine has rubber frame mounts to isolate the rider from the vibes, and the b engine has an internally balanced engine. what you want to do would effectively do away with both of those...
Old 07-03-2009 | 10:17 PM
vtwincam's Avatar
vtwincam
I know but wouldn't that be interesting!
Old 07-03-2009 | 11:09 PM
BlackRob's Avatar
BlackRob
Get ready for a paint shaker. Ride one of the old Evo SofTails (solid mounted, unbalanced) and you will quickly change your mind. Strictly a short range bike.
Old 07-04-2009 | 12:10 AM
Medicfrost's Avatar
Medicfrost
I supposed that if you had a strong enough luggage rack, anything is possible.
Old 07-04-2009 | 12:16 AM
Fross923's Avatar
Fross923
that ought to rattle all your teeth lol
Old 07-04-2009 | 01:55 AM
harleydavis's Avatar
harleydavis
It would require a significant change in the motor mounts on the softail frame, but probably could be done.
Old 07-04-2009 | 04:52 PM
Repoman's Avatar
Repoman
Just remove the balance shafts from the b motor currently in your bike if thats what your trying to achieve.
Old 07-04-2009 | 05:37 PM
DannyZ71's Avatar
DannyZ71
Shouldn't be any real trouble. The rubber mounts didn't come out until the mid to late 80s. Everything prior to that was solid mounted. And the vibration wasn't that bad in them. In fact, that rumble you felt when you cranked the throttle open let you know you were on an American machine. And it sure felt good.
Quick Reply: T/C 88-A in a softail?
