Nitrogen in tires??
Old 06-07-2009, 09:24 AM
stupid_rope's Avatar
stupid_rope
stupid_rope is offline
Originally Posted by togfish
I only use a special blend of 78.08% nitrogen, 20.95% oxygen, 0.93% argon, 0.038% carbon dioxide. It's worked well for me.
I breathe this stuff all day, everyday. But it's hard to get around here sometimes.
  #32
Old 06-07-2009, 09:37 AM
rockDAWG's Avatar
rockDAWG
rockDAWG is offline
Originally Posted by nhbouncer
the company I work for it cost $20 to fill all 4 tires with nitrogen and includes free top offs for the life of the tires. If you do a little research on the website link I provided www.getnitrogen.org you might learn a thing or two. yes you are correct that the air we breathe is nearly 80% nitrogen all ready but something else you my want to consider is the compressor being properly maintained so when they fill your tires they aren't blowing moisture into your tires because the compressor tank has condensation built up in it, I have actually seen tires come off cars with like a 1/4 cup of water inside them. Nitrogen prevents that from happening too on top of all the other things it does. By it being an inert gas it doesn't change the psi levels in your tires as much with temp. changes which we know can cause premature wear to your tires. So I guess you can make your own choice on it but as a person who sells, installs and uses nitrogen I recommend it.
From 78% Nitrogen in the air to 99% pure will make no difference in real life. It is nothing more than smart marketing gimmick. Of course you will recommend it because there is financial gain for you.
  #33
Old 06-07-2009, 11:03 AM
2whlr4life's Avatar
2whlr4life
2whlr4life is offline
Received 2,680 Likes on 1,517 Posts
Arrow nitrogen filled tires
My only problem with Nitrogen (aside from the cost), is that it wouldn't last that long for me. I can't help but check my air pressure regularly. It's only a matter of time before I'd have to add regular old air...
38 lbs. Front, 40 Rear. Cold. Solo riding.
  #34
Old 06-07-2009, 11:08 AM
neonhomer's Avatar
neonhomer
neonhomer is offline
Plus you get the pretty green valve stem caps.... LOL...
I don't go for the Nitrogen in tires hype..... I don't think you can remove enough of the regular air from the tire to get it completely filled with N2 to make it worth while.
I used to know A/C techs who would use R-22 in their hand cart tires. Used to also use it in his truck tires. Weird...
  #35
Old 06-09-2009, 07:12 PM
vonhetzer's Avatar
vonhetzer
vonhetzer is offline
6th Gear
Refrigrant is probably one on the worst things to put into your tires, due to the propeties it constantly has large changes due to temperature. For all you naysayers nitrogen is a very stable gas, that is why we use it to silver solder and pressure test refrigeration systems. I have it in my tires. My bike sat all winter long no change in pressure from last year to this year, not a large increase in pressure when the tires are hot either. I'm not saying I would spend $20 for it, but remember you are also paying for the labor involved and the evacuation of the "air" from the tires. If you have no experiance with it stop being a jerk off and making erronus claims and comments, you just steer people in the wrong direction when you may not be right.
  #36
Old 06-09-2009, 10:23 PM
MidnitEvil's Avatar
MidnitEvil
MidnitEvil is offline
If you want to learn more about what nitrogen can do check out www.getnitrogen.org it will tell you all about it. I manage a local tire store that does install nitrogen for customers. I run it in my bike and it does help stablize tire pressure and I run it in my car up here in New England it helps keep the moisture down inside the tire and help prevent wheel rust.
Does your tire store also offer siping?
iride1
03-18-2012 05:01 PM
RoadHog659
10-17-2011 09:07 AM
Chas63
03-12-2009 11:16 AM
beaucoup_dinkydow
04-22-2008 05:10 AM
TattooYoo
03-16-2007 03:23 AM
Quick Reply: Nitrogen in tires??
