Bar end Weights
I don't know if the weights will work with the 09 TBW bikes, but I do know from personal experience that the Kury ISO Grips install perfectly on the TBW bikes.
I think it depends on the bike you ride with the bar end weights. If you have a 88 or 96B balanced motor I don't see them making any difference. Of course if you have an A model motor they might. Personally, I never have a problem with the "Vibration" of my bars.
The ISO grips really soak up a lot of the vibes too. The wife has them on her sporty, and they are comfy.
Thanks guys! I had ISO's on my last bike and I miss them. I don't really feel the vibes all that bad on my Dyna but I like the "bigger" grip on the ISO's . .just seems to fit my hands better.
Have a good one,
Dave
Have a good one,
Dave
I have the ISO helmet lock on my right grip. It's OK as a helmet lock. Kinda pathetic as a "bar end weight" -- it just doesn't weigh anything to speak of. The ISO Grips are nice, comfy grips but not really anything more than that.
Let's just say that I have to wear my riding gloves all the time or the skin on my knuckles gets worn off from dragging on the ground when I walk.
(oh yeah . .and I never need sunglasses because my forehead provides plenty of shade)
I'm currently installling Kury ISO grips, and before I put the grips on I'm adding a role of nickels into each bar-end. I made a wooden plug out of dowling and put that in first. This is just in case the nickels break free; I dont want them down in the bottom of the bar. I used my bench grinder to get the dowling to the correct size to fit snugly. Then I wrapped a layer of packaging tape around each role of nickels to insure the paper role doesn't ever break. I tapped in the plug to the correct depth then installed the nickels which fit in very snuggly; perfect fit.
I've always heard this trick works and since I've got the grips off, it cant hurt to invest the $4.00. I'm getting numb hands with the stock grips, so the nickels + the ISO grips should help solve this problem.
