No Wheel Weights/Balancing??
Old 05-22-2009, 08:12 AM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,661 Likes on 946 Posts
The next step for those that have learned the secret of "Dyna Beads" is plain old air-soft pellets. I got tired of paying the high price for the ceramic beads and having to order them in advance. I've been using the same weight of air-soft pellets (I use the dense .2 gm ones). A $5 jug of them from Walmart will do about 12-15 tires. Cant put them in through the valve stem however. Only good at tire change time, and only on tubeless. I put them under the bead before I pop the tire up. Work TERRIFIC, and sound like a maraca when you roll the bike around without the engine running.
Old 05-22-2009, 10:37 AM
AdrianVall's Avatar
AdrianVall
AdrianVall is offline
These dyna beads can be inserted through the air valve stem? How the hell would that work out? I need to get these.. but I just put new tires on and I'm not about to take them off for these beads.
Old 05-22-2009, 10:56 AM
G Rod's Avatar
G Rod
G Rod is offline
The dyna beads come with good instructions and are easy to work with. Oh yeah, they work well too.
Old 05-22-2009, 11:33 AM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,948 Likes on 1,932 Posts
The dyna beads come with a tube for inserting them into the valve stem, although if going tubeless it makes more sense to just dump them in the tire before getting it all the way on the rim. that being said, my tires did not get balanced or weigjhted and are still perfect. I go to an old school indy and the guy told me not to bother.
We'll see how long they last like this. I'll let you guys know.
__________________
hanny
2014-2023 Touring Models
03-29-2014 07:28 AM
HubrisHCC
01-20-2013 09:19 AM
kyleplusitunes
10-05-2011 10:18 PM
Hot_Pasta
Wheels/Tires
07-19-2010 11:01 AM
t059736
11-15-2007 09:28 AM
Quick Reply: No Wheel Weights/Balancing??
