not Comfortable riding mountain roads
#61
#62
Have been going through the exact same thing myself. The advice about not looking down at your front wheel or to a spot only 30 feet in front of you is bang on!!!!! I have learned to do the twisties better but can't do them at 2 or 3 times the "recommended" speed. I know where I am going (and when with a group, where we are going) and I'll catch up!!!
Don't feel that you have to scrape the boards on every turn.
#63
I only saw one post in this thread where someone mentioned downshifting, and I have to agree - especially at higher speeds.
Keeping the bike in the power band through turns gives you one more way to adjust your lean angle. A little more throttle to comfortably increase the lean, a little less to decrease it.
There's nothing worse for me than "coasting" through a turn or having to use the rear brake in one because of traffic. Feels like I don't have the control I should.
When we ride the twisties I make it a point not to use my brakes before or in the turns, makes the ride a lot smoother and more enjoyable.
#64
Speaking of Texas (though even in the DFW you can find "some" twisties, short and limited though they are) there's one other tip I would throw out there. A problem I encounter here is road conditions. The two biggest problems are gravel on a curve where a farm road meets up with it, and tar snakes on the curves when it's 100 degrees out. So even though I'm not focusing on the road in front of me, I try to stay aware of the road conditions going into the turn since, if I see tar snakes entering it, there will probably still be tar snakes in the turn itself so I slow down on those turns. Since things are mostly flat you can usually see a farm road past the turn even if high grass makes it hard to see the road in the turn itself.
#65
I feel the same way. My electrglide is great for riding down the interstate, but riding moutain roads it is not. I have drug floorboards in parking lots. I also slammed it into a guardrail on a mountain road back when I thought I knew what I was doing. Wish I would have pulled over and enjoyed the mountain view.
It is amazing how little concern I had for the bike as I was flying through the air and then trying to figure out if all of my limbs were still attached, and oh yea, where is the blood coming from.
#66
#67
Ionly have approx. 800 miles in the past 3 weeks on my 09-E.G. but 80% twisties Juliun, Big Bear, Ortega Our friends lead my wife and I on some good ones. But I did take it slow and didnt let traffic pressure me I would just take at my own pace.
The best tips are counter steer and look ahead at where you want to go. I also have gone through quit a few track days at Willow springs in older sports cars and the thinking is the same as far as looking ahead and choosing a line. One other thought that really has helped me is weight transfer, brake and decel in a straight line not in a turn just keep even power and slightly accel out of a turn. I do recommend the rider safty course I just completed the first day today and have the remainder tomarrow a.m.
I do plan on praticing skills I have learned in course and from this site. We need to reduce as much risk as possible. Jeff
#68
Good point. I had forgotten about that one also. Unless I'm going at a decent angle downhill into a turn, I try to avoid using my brakes and kick myself mentally if I do end up not being able to slow down enough just through downshifting, then start to kick it back up again in the turn.
#69
The secret to good riding is good technique. You develop good technique through good riding. So its kind of a loop., just go out there and ride that twisty, and then do it again, and again. You should always challenge yourself to be a better rider, its a lifelong quest.
As for twisties in particular, one of the biggies is stay off that front brake. It serves a purpose, but leaned over in a curve it will drag you to the asphalt like a magnet. Feel free to gently drag the rear brake if you need to.
#70
Your post gets my vote...for the worst advise ever...no one ever learned anything watching the bike in front of him...JMPO...you got your opinion..I got mine...
