View Poll Results: A poll
I use 87 Octane
5.19%
I use 89 Octane
1.48%
I use 92 octane
68.15%
I use 94 Octane or higher
9.63%
I use lower but add octane boost
0%
I believe using lower than 92 will damage motor
3.70%
I use whatever and it's runs like a locomotive
2.22%
It isn't worth the price difference to take a chance run 92
9.63%
Voters: 135. You may not vote on this poll
what Octane Gas do you use?
Old 05-10-2006, 01:41 PM
DDDeepdiver's Avatar
DDDeepdiver
DDDeepdiver is offline
Default RE: what Octane Gas do you use?
i use 93 also...cant see how saving $1.00 on a fillup would make you want to use a lower octane.
Old 05-10-2006, 01:45 PM
thunderbirdblue2's Avatar
thunderbirdblue2
thunderbirdblue2 is offline
It's my bike and I want it to last many years... so 93+ is what I use...
Old 05-10-2006, 02:02 PM
Clammy's Avatar
Clammy
Clammy is offline
Received 1,915 Likes on 816 Posts
I always use Sunoco 94 unless I can't find it, then it's the highest Octane available. I've never put anything lower than 91 in my Night Train.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old 05-10-2006, 02:06 PM
SPRINGER's Avatar
SPRINGER
SPRINGER is offline
Received 3,270 Likes on 1,976 Posts
I don't really know what the octane rating is, I just use Premium and nothing else.
Old 05-10-2006, 02:13 PM
sporty2003's Avatar
sporty2003
sporty2003 is offline
i run B.P. 92 i would run higher if i could find it . but it runs good on the 92.
Old 05-10-2006, 02:40 PM
lapisblue's Avatar
lapisblue
lapisblue is offline
I used to run Avgas, it's a high-octane fuel used for aircraft. I think it was over 100 octane and loaded with lead. I used this in my panhead whenever I went to the Harley shop (It was a combination airport /Harley shop). I wonder if you could run this fuel in the EFI bikes today?
Old 05-10-2006, 07:11 PM
kemp427's Avatar
kemp427
kemp427 is offline
i have a question I have some "Cool Blue" racing fuel i used to use in my stock car its around 100 can you use that in a bike. Rather is it healthy for the bike?
Old 05-10-2006, 08:02 PM
Tommy Meisel's Avatar
Tommy Meisel
Tommy Meisel is offline
I must be lucky. My Harlely runs just fine all the time. I was using 93 octane premium for a while, now I mix the 93 and the 89 and it still runs great. I usually fill when I am down to about 2 gallons, and if I alternate each fill with 93 and 89, I am running an average of about 91 octane, with a range between 90 and 92.
All the fuel here has ethanol (Illinois is the corn center of the world and corn farmers like ethanol and so we have it), and I confess that it runs just fine, although I know that my mileage is reduced somewhat, and if I am too lean on 100 percent gasoline I will for certain sure be too lean on 10 percent ethanol. Right now I have the stage 1 air cleaner and reflash, but I am running the stock mufflers, so I am a bit rich, which solves a lot of problems. I have been averaging 45 miles per gallon with a mix of city/freeway running.
If this bike ran any better I would just die from happiness, it is so good already!
Old 05-10-2006, 08:15 PM
eazy's Avatar
eazy
eazy is offline
ORIGINAL: lapisblue
Not sure the lead would be good in an injected. I'm no engine mechanic, but I wouldn't use it. The lead may deposit on the injectors
Old 05-10-2006, 08:30 PM
Brettsterhog's Avatar
Brettsterhog
Brettsterhog is offline
I have always filled up with the 92 in my motorcycles, snowmobiles, and everything else that doesn't hold over 10 gallons and I am more picky with. HOWEVER, I got to thinking the other day. The experts say that todays gasoline is technically "stale" after 30 days. If this is the case, and with gas prices the way they are, I don't think the good ole Premium (92 or higher octane) is coming out of those underground tanks very fast. For this reason, I started filling up with 87. The bike runs the same, no pinging and I am thinking fresher 87 may actually be better for the bike than older 92. Just a thought.
Quick Reply: what Octane Gas do you use?
