Redline oil cahnge
Redline oil cahnge
Just wondering if any of you guys or gals have dropped redline oil out of your tranny and replaced it with another brand ?? If I decide to do this will I have to flush the tranny out or will the small amount left behind mix ok with other synthetic or mineral oils ?? I am assuming it will be ok but just checking.
I drained out Red-Line Heavy Shockproof last October and replaced it with Rev-Tech 80W-90....Trans is doing fine! The Red-Line was too thick for Winter-time...
With all due respect, the Rev-Tech 80W-90 has less bronze particles in it when it is drained out...I change the trans fluid every 800-1,000-miles...Changing fluid often is cheaper than pulling the trans and changing gears/shafts/forks!!!!
really? that would be like changing it every month! the spec is to change it every 20k, so that is some serious overkill.
that to me would be more important than changing the tranny at 1k
bad, davidson, davidsons, default, good, harley, heavy, line, mixing, oil, red, redline, shockproof, shovelhead, transmission
