Backrest on roadking tourpak
RE: Backrest on roadking tourpak
There is a new leather tour pak that is larger ,that you can get an arm rest for . If you look at my bike I fitted a arm rest on my tour pak . The arms stick out from thesides of the tour pak .I made some custom filler panels and covered them in vinyl . Sure beats two grand for the newer one. Picture isnt the best.
Yes, you can make one fit as Stile45 did above. The mounting points are different so you'll need to fabricate the mounting. You can find the backrests on E-bay pretty cheap.
thanks for the replies. i have been already watching ebay for one.
i planed on trying it any way.
I knew it would be wider than the tour-pak but i thought if i took the
cover off i might be able to cut it down and then recover the padding.
smokindave
04-20-2008 12:32 AM
