found oil leak
Old 04-26-2009 | 03:07 PM
propane_peddler's Avatar
propane_peddler
If it is a seal, mainshaft or shifter, it shouldn't be that big of a deal, a day at the most. Also check the transmission breather hose, I have had that plugged and makes for a trans fluid leak.
Old 04-26-2009 | 08:28 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
You mentioned you just had it serviced. Did they change the trans oil? If so I bet it's a tad full, and vented on the ride. For instance my tranny takes (by the book) 24 ozs. I put in 22 ozs. the minimum amount is 20 ozs. No more venting for me.
Old 04-26-2009 | 08:38 PM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by ChopinRockwooD
I got the extended 7 year warranty but had a bit of engine work done so not sure if it would be a valid complaint. it seems these days anything you do VOIDS the warranty!
The engine work has nothing to with a tranny leak.
You should be covered.
Old 05-08-2009 | 02:44 PM
CurtO's Avatar
CurtO
Tranny is too full. I just had the same problem with mine. Drain a couple of ounces out of the tranny.
Old 05-08-2009 | 03:02 PM
cadman311's Avatar
cadman311
You people are Funny
Old 05-08-2009 | 03:09 PM
ChopinRockwooD's Avatar
ChopinRockwooD
Thanks to all who replied, I had the leak fixed last week and the problem they told me was the mainshaft gasket or seal(something like that)???? Anyhow leak is fixed, covered under warranty and they even covered my deductable, Shhhh. Thanks for all the help.
Old 05-08-2009 | 03:22 PM
cadman311's Avatar
cadman311
Did they fix the bearing to go with that.
Baccerman
EVO
13
10-17-2015 06:49 PM
limeyhusker
EVO
15
07-10-2013 09:40 AM
Tactical111
EVO
19
11-08-2010 05:41 PM
Trex
06-20-2010 11:15 AM
hotrod351
EVO
01-21-2007 02:24 PM
Quick Reply: found oil leak
