draggin' the rear brake
No..... if you tuck the front end, the front end slides away from the contact patch and thus a LOWSIDE, much easier path onto the pavement for the rider.
When the rear swings out perpendicular to travel path, and the rear tire suddenly gets traction, the bike HIGHSIDES, ejecting the rider high into the air in an arc.
Been trailing the front brake for years started doing it years ago on the track when I was racing .Leaned over hanging off knee on the ground trailing the front brake.I still use the technique on the street (with out the knee draggin) LOL
Went out today and tried front brake draging took a few turns to get it down it does the same as the rear but felt funky This is not something I do all the time but if you work the brake and throttle at the same time you can take a ho hum turn and make it exciting.
all this and all anyone had to say was watch the Ride like a Pro videos. Rear braking at slow speed... (ie uturns) will keep you upright....front brake will drop you to the ground in an instant... while I don't rear brake in corners at high speed... I do during say on/off ramps....and as stated during slow turns... it works is all I can say!!
I've been riding as long as I can remenber, and legally since I was 16 (waaaay back in '92), and he slow speed rear brake with half clutch was the only thing I got out of the RLAP vid, and it was worth whatever I paid for the video. Previously I'd just give a short bit of power and pull in the clutch and coast at a walking pace, every once in a while letting out the clutch a little to gain a bit of speed and stability then coast clutch in again trying to keep my balance. Now I've been riding the rear brake and the clutch at these speeds and a lot less effort is needed to balance.
But this vid does not address any high-speed cornering and brake trailing, which I had never heard of until this thread. Interesting topic. I love the twisties! And if there's anything that will help me navigate safely faster through them without dragging any more than I already do, I'm all ears.
no one is saying grab a handful of front brake in a corner and lock the front wheel and tuck the front end but if used correctly the front brake can be a very valuable tool.This is what 3 time world champion Freddie Spencer use to teach in his performance riding school for the track and the street
excellent reading and short.
http://powersports.honda.com/experie...motocycle.aspx
here is the summary
Brake/Throttle
The final part of the steering equation we teach at the Freddie Spencer High Performance Riding School involves application of the brake and throttle. We teach that the most important aspect of each corner is the entrance, dubbed Zone 1 in the school. Brake and throttle usage in Zone 1 are essential to successfully navigating the rest of the corner. Both brake and throttle input have a tremendous affect on how the motorcycle steers when used in conjunction with the other methods I've described above.
Braking for a corner loads the front tire, compresses the front suspension and tightens rake and trail, allowing the motorcycle to steer more quickly. Trail braking well past the turn-in point allows the rider to continue slowing the bike and help it steer, adjusting the line if need be while maintaining the load factor on the front tire. The throttle is used in much the same way; rolling it off and squeezing the brake will cause the motorcycle's line to tighten, cracking the throttle off idle after the brakes are released arrests the bike's lean angle and helps hold the desired line
here is the summary
Brake/Throttle
Received 4,802 Likes
Wow, The MDDC (motorcycle defensive driving course) that the Dept of Defense was using in the 70's and 80's covered all the aforementioned braking techniques and taught Countersteering as an evasive manuever. I read something in a bike magazine about rear braking in turns tricks the frame into "thinking the bike is longer and the opposite is true for front braking. I do rear braking in city situations and on long sweeping turns.
