Primary Oil Level
Old 04-13-2009, 07:42 PM
l.ray's Avatar
l.ray
l.ray is offline
Oil goes in that derby hole?? Now thats turd shifting! L Ray
Old 04-13-2009, 08:17 PM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,540 Likes on 932 Posts
Overfilling will make it harder to find neutal. My 06 softail calls for 26ozs & the 09 softail 32ozs.
Old 04-14-2009, 12:33 AM
Dustball's Avatar
Dustball
Dustball is offline
Originally Posted by OldFenderGuy
On my Softail FatBoy 29 ounces is about right.
On my RoadKing 33 ounces is about right....
99.99999% of the people I know just drain the fluid and add 1 quart, no matter what model of bike they have....
Most of them have a lot of miles on their various bikes, and even when using the quick and esay "1 Quart" method nobody has ever had a problem....
+1 on the 1 qt method.
Old 04-14-2009, 08:40 AM
Danowert's Avatar
Danowert
Danowert is offline
Curious why you would fill through the derby cover when you should be pulling the inspection cover and checking the tension on your chain if your using that set up. Inspection cover allows you to see and make sure the chain is running in the oil and that the bottom of the clutch basket drags through the oil also.
Old 04-14-2009, 08:57 AM
Splatter's Avatar
Splatter
Splatter is offline
Pro'ly 'cause newer bikes don't have inspection covers. They have self-tensioning chains so there's nothing to inspect. (where's the little emoticon of the guy rolling around laughing?)
Old 04-14-2009, 09:12 AM
Danowert's Avatar
Danowert
Danowert is offline
Cool
Uhh..Excuse me??? 2004 Road King doesn't have an inspection cover. Hmmm doesn't have a chain adjuster either. Wow wonder what I've done maintenance on then in the past for customers?
Old 04-14-2009, 09:13 AM
sandman2004's Avatar
sandman2004
sandman2004 is offline
Originally Posted by seniorsuperglideE8
My 02 and 05 Dyna's both take 26 ozs. of primary oil, now maybe the touring bikes take the full quart. My service manual also has a caution about possible clutch problems from overfilling. Invest in a service manual, I guess I'm the .000001%, right?
Me too
Old 04-14-2009, 09:57 AM
Deepsouth251's Avatar
Deepsouth251
Deepsouth251 is offline
I really don't see any reason to check primary oil level between changes. I mean, it goes in at the time you change it. It can't be burnt like in the engine as it is for lubrication only, ie is not exposed to heat extremes like in the engine and if it is not leaking, where's it going to go.
Old 04-14-2009, 10:27 AM
Danowert's Avatar
Danowert
Danowert is offline
It not just a matter of checking level its also for looking at potential problems. Flakes, chips, sludge. Also if any breakdown of the oil is noticed. The clutch pack breaks down and adds to the contamination of the oil. If you do a lot of stop and go city riding it will wear the clutch pack disks down much quicker and in turn create bits and pieces. Moisture from the heating cycle will also sludge up the oil.
Also the primary gets hot, maybe not to the degree that the cylinders or heads do but certainly as hot as the case. Try touching the primary after a 1 hour ride in 70 degree weather. Clutch plates when worn will turn blue if over heated from excessive slippage. All of this contributes to oil break down.
Old 04-14-2009, 10:38 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
My dyna gets 1 quart in the primary and one in the trans. Way too easy. Just drain hot and fill to the book spec for your bike. The capacity is listed in the owners manual. I never inspect it. Just change it. Thet is why I use synthetic oil that is overkill. I am never going to run it beyond the limits of the redline synthetic oil I use and only change once a year. fill & forget. The trans gets shockproof heavy and gets changed every two years and it still looks like new.
Quick Reply: Primary Oil Level
