Brake pedal assitance
Hello all. Last night I put on the Kurkyan offset peg mounts so that the forward controls wouldnt be so far away for me.
I was able to adjust the shifter with little difficulty but is there a way to raise the brake pedal up a little so I am not pushing down so far?
Thanks
Thanks
RE: Brake pedal assitance
If it is a Dyna, the rear master cylinder is located at the end of the brake rod near the rear tire. The rear of the brake rod is threaded and depending on how you adjust the rod, in or out of the threaded connection to the Master Cylinder, the pedal will raise or lower accordingly.
Hey thanks, I am sorry I forgot to advise. It is a 2005 Dyna superglide and that is where I will look when I get home.
I just need it up about a 1/4 inch or so.
