stuck on the interstate
Old 04-03-2009, 08:06 PM
donkey_soldier's Avatar
donkey_soldier
donkey_soldier is offline
3rd Gear
Default stuck on the interstate
I just want to know if this has happened to anyone else? Was riding back from my two day trip and my 93 FXR starting acting like it was out of fuel. Day one had about 250 miles and I was only 100 miles into day two. It just lost all throttle. I pulled over to the side of the interstate let it rest for a couple of minutes and then she ran for another mile and did it again switched it to my reserve tank even though i wasnt out fuel. I ran to the next gas station filled her up, only took a half a tank, and she ran fine. Any ideas?
Old 04-03-2009, 08:16 PM
paulies 07's Avatar
paulies 07
paulies 07 is offline
Dunno, bad gas, blocked fuel line? Are you running an inline fuel filter?
Old 04-03-2009, 08:20 PM
flylock's Avatar
flylock
flylock is offline
Could be the petcock, or the gas cap.
Old 04-03-2009, 08:43 PM
mslater741's Avatar
mslater741
mslater741 is offline
could be a hole in the fuel line inside the tank...when you filled it with gas it brought the level above the hole so it wasnt sucking air.. sounds like what i had happen
Old 04-03-2009, 08:59 PM
donkey_soldier
3rd Gear
I am thinking of tearing the gas tank off and cleaning the lines possibly replacing them.
Old 04-03-2009, 09:04 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
If you have a vacuum operated petcock you might have a vacuum leak, were you pulling hard at the time? maybe going up hill? low vacuum will shut off the fuel flow.
Old 04-03-2009, 09:06 PM
oldairboater's Avatar
oldairboater
oldairboater is offline
I would pull the tank petcock and inspect it.
Old 04-03-2009, 09:08 PM
donkey_soldier
3rd Gear
I had been riding pretty hard. How could I double check the vacuum?
Old 04-03-2009, 09:18 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
Spray WD40 on the vacuum line in question while the bike is idling, it should make no difference to the idle speed, if it does you have a leak.
Old 04-04-2009, 04:35 AM
dog155's Avatar
dog155
dog155 is offline
The screens on the petcocks will plug,sounds like you have other problems.Maybe a good time to get rid of vacumn shut off if you have it.
Quick Reply: stuck on the interstate
