horn 139db
horn 139db
Just ordered a horn off Ebay $20 , sayshttp://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?MfcISAPICommand=ViewItem&item=458157 1095 it will fit under cow bell . For $20 I take a chance.
RE: horn 139db
I got one last week.
If you put it under the cowbell you'll need to take the gray plastic back off and bend the electric connectors a bit so the bike connectors will slip right on. It is loud!! You get a choice of high tone or low. The low is similar to stock but definitely louder. The high sounds like Paris traffic.
RE: horn 139db
ORIGINAL: stile45
I shure hope that your not in a hurry to get that horn.
Last month or so, I purchased the Stebel Nautilus horn from that exact same seller. It took almost a month for my horn to arrive. Its a loud horn, just took forever compaired to most other items I have purchased from e-bay. I have left coment reguarding the horn bing as advertised just took a long time for him to ship. It did arrive in great shape.
http://cgi.ebay.com/ebaymotors/aw-cg...tem=4576944563
You may want to take a closer look at his feed back!
You need to keep in contact with him an keep a copy of all your corrispondance in case you have to get your money back. I'd keep a note of all the dates you contact him to keep things straight too.
Good luck with the purchase. A lot more people have lost much more then the price of your horn.
RE: horn 139db
ORIGINAL: ricoman
And here I was trying to think of how to make the bolt longer so it'd fit! THANKS!!!!!
I'd hooked it up to compare before I tried to install it. It is LOUDER than stock!
RE: horn 139db
Fits right under the cowbell with minor mod as noted above. It will da*m sure get you noticed!
RE: horn 139db
Some Pictures please I would like to see it fitted before I get one as the Harley one is made by the same company (It looks identical) but and replaces the cow bell as the horn is chrome whereas the Stebel one is black.
RE: horn 139db
It,s o.k. Sugar. The cowbell's the horn cover on the left side of your bike. Opposit of the muffler side. Looks like a cowbell. Hang right between the jugs.
