broken belt
Old 03-22-2009 | 10:14 PM
pearson's Avatar
pearson
Stage II
Unhappy broken belt
my belt just broke tonight on my 03 roadking. lucky enough to be in my driveway. anyone know how to change a belt?
Old 03-22-2009 | 10:48 PM
oldairboater's Avatar
oldairboater
Yes, word of advice get a manual. Belts are more than just belts. You can't pinch them new, tension is very important. You will have to remove outer primary cover, clutch, compensator,primary chain, and rear wheel. Not a ten minute job.
Old 03-22-2009 | 11:06 PM
bagman1's Avatar
bagman1
Also need to remove the inner primary too and the swing arm.
Old 03-22-2009 | 11:29 PM
oldairboater
Why swingarm?I knew about the inner primary but not the swingarm.
Old 03-22-2009 | 11:42 PM
bagman1's Avatar
bagman1
Because the belt has to go over and under the bolt of the swingarm.
Da Gumpmeister's Avatar
Da Gumpmeister
Old 03-22-2009 | 11:58 PM
mplecha's Avatar
mplecha
how did it break?
Old 03-23-2009 | 08:07 AM
bagman1's Avatar
bagman1
Hey Dagump, do you know a shortcut? The book says to remove swingarm. If theres a shorter way to do it w/o wrecking the new belt thats way better than going thru all that work. Do tell.
Old 03-23-2009 | 08:34 AM
Notgrownup's Avatar
Notgrownup
Shortcuts=f-ups
Old 03-23-2009 | 08:46 AM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
Swing arm pivot has to be dropped.
Quick Reply: broken belt
