Helmet Lock
Old 04-27-2006 | 11:28 AM
SilverDawg's Avatar
SilverDawg
Default Helmet Lock
Did a search for this and found very little. I have a half helment. How do these things work with that type of helmet. Is the HD any good? Anything better on aftermarket?
I just bought the HD Kevlar helmet and don't want someone else to own it
Old 04-27-2006 | 11:34 AM
DDDeepdiver's Avatar
DDDeepdiver
Default RE: Helmet Lock
I have the HD helmet lock. It looks good and works as it should. I think any type would be just as good.
Old 04-27-2006 | 11:44 AM
billnourse's Avatar
billnourse
We have the HD models on the down tubes of our bikes, and they work well. They will work on the down tube if you have a half helmet. A full face will require mounting somewhere else for there to be room for the helmet.
Regards,
Bill
Old 04-27-2006 | 01:28 PM
ricoman's Avatar
ricoman
The HD locks work well. You can also get a brake lock and reminder cable. Just run the cable through the helmet D-ring before you put the lock on the front brake.
Old 04-27-2006 | 05:16 PM
skos's Avatar
skos
What stops someone from just yanking it off or cutting it?
Old 04-27-2006 | 05:18 PM
Rhubarb's Avatar
Rhubarb
ORIGINAL: skos
Nothing...
But it does keep a kid from walking by and picking it up because he can.
Old 04-27-2006 | 07:49 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Old 04-27-2006 | 08:04 PM
Protrucker's Avatar
Protrucker
I've got a helmet lock almost identical to the one in Neggy's picture on my atv. I bought it from J.C. Whitney.
Old 04-27-2006 | 10:58 PM
alexcue's Avatar
alexcue
ORIGINAL: skos
what good is a helmet with a cut strap?
Old 04-28-2006 | 12:26 AM
Camera108's Avatar
Camera108
I put Ky IsoGrips on each bike (02 Dynsa, 05 Sportster, 06 Street Glide). On the Dyna & Sporty, I put "bar-enders" which are keys for both sides, On the SG I put a new end lock made just for IsoGrips. Found them at both EBay and Eastern Performance (Maryland near me). Both work great. Helps with the illusion that if the bike were stollen, you would have to cut off the helmets before ridden away. Juat another step and time to discourage the theft.
Only complaint, the bar enders can lose the end if you don't push it all the way on when puttng it back.
Found the bar-enders in Daytona and the second pair on the web. Neither type is cheap, but work well.
skikp
Quick Reply: Helmet Lock
