wiring thru bars help!!!!!
help!!! I just got a pair of "wild 1's" 504's.....is there any instructions on running the wires thru the bars?
do i splice the wires??Where do i spilce 'em???
any help is appreciated. The bike is sitting in pieces now!!!!
hopefully it rains tomorrow so i dont miss any riding time!!!
RE: wiring thru bars help!!!!!
Im about to do the same, but Im getting HD street slammers.
do you have service manual?
I got the instructions for the HD bars Im pretty sure is about the same for you
if you want to talk on yahoo messanger It would be alot faster than posting here
ORIGINAL: blz2503
This is an exerpt from another thread but it should help explain things. These were WO501's on an 06'dyna. Hope it helps!!
Rick
ill get those pics for ya asap. The harley bars with the seperate rises are the easiest way to go. Looking back I probably would have done that even though I love the bars I got. The reason you have to get to the wiring harness is not for the speedo... thats fine. Its the controls on the left and right side. They are fed through the handlebars to make for a cleaner look. The wires run on the outside of the bars for the stock ones. Sure..... you could just cut the control wires and butt splice them but then you will notice it and leave the window open for bad connections. So... when you dig into the frame you can find the plug for each sides harness. Disassemble the harness and get each individual wire out, run it through the handlebars, reconnect the plug and put it back together. Doing it that way keeps everything just like it was coming from the factory except for the fact that you now have the f-ing coolest bars out there. Long winded but I think you get the point
Rick
Rick
Rick
bike is an '06 fatboy.
So if i am reading this correctly...i can unconnect the wires wiythout any splicing..correct? They are located behind the triple-tree
thanks for the help!
blz2503, the harness plug is located under the gas tank. I have not done this, but what I have read you can unbolt the tank and slide it back a couple inches to get at the plug. Before you de-pin wires from plug draw a pic or write down which color wire goes in the plug.
