S.E. 260 cam
I just finihed the 103" with SE 260's, rods, mild port, springs, SERT, 10.5.1 forged pistons and put 22 miles on it then the rain came. I need a few hundred miles on it then will do the dyno and post the numbers.
i will be installing the 260's in my bike here withen the next week, i am waiting for them to come in, i will be running a 103" with branch heads, cp pistons, compression will be 10.4/1 and using the EXILE hi/low drag pipes. Motor work has allready been done but i was using a 255. by the end of the week i should be posting my results on the dyno.
I have the SE 260 cams in m 103" build. SE pro CNC ported heads, 50mm throttle bodies, hi flow injectors, 10.5 comp HTCC pistons, some few other odds and ends inside but don't recall offhand. Have posted numbers elsewhere.
Bottom line numbers in sig.
The video speaks for itself.....
http://www.youtube.com/watch?v=trtxe...e=channel_page
Here is a link to my dyno post a few weeks ago. Now the bike is fully run in; it wil be re-dynoed and tuned again within probably the next 2 weeks.
https://www.hdforums.com/forum/dyna-...o-numbers.html
Post whoring,
here is a link to a discussion of hi-lift long duration cams.......
https://www.hdforums.com/forum/dyna-...o-results.html
i got 103 hp and 109 lbs of torque with my setup i will be installing a heavy breather well as soon as i can save up for it and getting the bike re dynoed hopefully squeezing a few more out of her.
