Reverse fork . . .
If I understand it correctly, the forks are situated behind the pivot point where the front forks connect to the frame. On the other models, the forks lye infront of the pivot no?
The result? After you come out of a turn, the front end straightens itself out with very little effort. In other words, self-centering.
I guess I should have asked if there is a down side to this feature as none of the other models, as far as I know, have this setup.
The reason is it not offered is because it is hard to hide. The front of the Touring frame looks like a long necked goose. You can hide it decently under a RK nacelle and very well under the fairings of the other bikes.
The reversed triple trees make the Touring models far superior at very slow speeds. They have zero flop. Even the best of the other bikes feel kinda top heavy at walking speeds.
Thanks for the explanation. That's what I like about this forum. I'm learning something new all the time.
Received 1,297 Likes
It appears that it's more possible to experience a high speed tank slapper with these reversed forks, compared to regular fork geometry. At least that seems to be what I've heard from several sources. It can have more sources than you can shake a stick at on a day off work: Neck bearing wear/misadjustment, wheel bearing wear, wheel bearing side-play, loose spokes, tire wear, incorrect tire inflation, engine mount wear, swingarm misalignment, swingarm bearing wear, total bike alignment.
My guess, and it is only a semi-educated guess, is that the unusual front end geometry is more affected by anything else not being nearly perfect than that of a bike with "normal" front end geometry.
