Windshield and front turning signals - problem??
My hubby is installing a Memphis Shades ( a "FAT" model) windshield on my 2008 Street Bob. He says it won't work unless he moves the front turning signals down onto my front fork because the way it is now my front turn signals are hidden by the shield - specifically by the cross bar on the shield. I had this problem on my Nightster and that's what he did, but I am wondering - for those of you who ride with a windshield, do any of you ride with your turn signals behind your windshield, or have you moved them? I don't think it's a big deal. He does.
He is also thinking this shield is going to be too tall for me (it's an old one of his), and so if I have to buy a new one that's lower, I suppose I could buy a "SLIM", (if that would even make any difference in regard to the signals) but I don't really want to do that because I'm afraid I'll get more buffetting. Before I go buying anything new, if it's necessary, I figure'd I'd post here for some input.
Help?? Comments? Thanks.
I moved my turn signals down to the forks, but for different reasons. I was switching over to ape hangers and thought they'd look odd way up there. I have heard of people taking their shields into glass repair stores and having them cut them down. You might try that.
Most like to just look over the top of a shield in case of a down pour so the old man can handle that cut or mark with masking tape and take to a glass shop and have them cut and polish it for you. The turn signals do typicaly get moved down to the lower tree area. If your lower tree has screws on the side you could drill out your lights mounting holes and get some bolts long enough to go though from the inside of the light and screw directly to the tree cost just 2 bolts and 2 nuts and a couple minutes to drill the lights hole out larger. I have done that move on a couple sporty's and dynas along with my current fxr. If you don't have the screw holes in the trees go to hd parts and buy the mount kit ,wires should move to that spot just fine and tie off with a couple extra plastic ties.
Hey thanks guys. The height of the windshield, and the turn signals are two different problems. I just sat on the bike and I do think even if hubby moves the shield down as far as it goes, (there's still about an inch or so he can go down), I'll still be looking through it and so I will need to have a shorter shield. His "old" shield was barely used and the color on the lower half matches my bike nicely. That's why we decided to try it.
The problem still is the turn signals and I suppose we can just move them like I had to with my Nightster. I was just hoping not to have to do that. To me, I think the signals are peaking out a bit from the windshield. Hubby thinks not and that it's dangerous. So now I have to decide if I will go to a "Slims" shade and maybe overcome THAT obstacle, or stay with a "Fats" shade and move the signals. Decisions, decisions.
The issue I had with the signal lights in the stock location on the Softail Custom I used to own was, at night the running lights reflected off the winshield interfering with my night vision....
So I used the signal light relocation kit to move the lights down on the forks. I had Memphis Lowers deflectors on the forks where I had to move them down about an inch to accommodate the signal lights so then the helmet buffeting got a little worse...
Part number of the relocation kit for your 08 Street Bob if you don't already have it is.... 69433-08
If the bottom color obscures the signals, I'd say you need to go with a slimmer shield or relocate the signals.
I think the signals look better where they are.
Looking at the slim shades on the memphis site I'm wondering what would stop you from trimming the top and sides of the one you have now to clear the signals.
If you have a jigsaw cutting a windshield is easy. Plenty of info online as to how it's done. I cut 1-1/2" off the top of mine and it looks factory.
More great thoughts. THanks again! Gives me some options. That's what I love about this forum. THere always seems to be SOMEONE who has had a similar problem, or just has some good suggestions.
Nilla
08-02-2013 10:10 PM
machm1969
11-03-2012 06:49 AM
