Are the XIEDs right for my situation?
Old 02-04-2009, 11:18 AM
stuey922's Avatar
stuey922
stuey922 is offline
Default Are the XIEDs right for my situation?
Unfortunately, I,like so many others, have recently lost my job. So a full stage 1 upgrade is out of the question for the time being. I have just bought a set rush slip-ons with a 2 inch baffle for my 08' crossbones. Since I can not afford a tuner at this time I was thinking of putting the XIEDs on my bike. Without changing anything else on the bike do you think this will let the bike run decent without damaging anything. I am not looking for more power out of the set up just a little more bark and hopefully a little cooler running.
Old 02-04-2009, 08:46 PM
ezriderpgh's Avatar
ezriderpgh
ezriderpgh is offline
Xied's would be good for your situation. As long as you're not changing the air intake they will provide a lil pop in the throttle and cooler temps in traffic and around town. I have had them on 2 bikes and was happy with them, they do what they claim.
Old 02-04-2009, 09:38 PM
DoomBuggy's Avatar
DoomBuggy
DoomBuggy is offline
Sounds like a plan. If you are interested I have a set that I used on my '08 before I went to the SERT. They are yours for $50.00 if you are interested. Drop me a line.
-Harry
Old 02-04-2009, 09:50 PM
jbphoto's Avatar
jbphoto
jbphoto is offline
Stuey922, I'd say give doombuggy a PM. That's a good deal.
I've had XiEDs on my 08 Bob for the past 6000 miles. I have V&H slipons and, as yet, I've done nothing else for performance. The XiEDs do make a difference. This month I plan to have a stage 1 air cleaner plus the download installed. I will still run the XiEDs rather than go to a SERT etc. My thinking is that with the additional air flow and the minor remapping mods that the download provides that the enrichening from the XiEDs should continue to work just fine. Now if I tempted to do some racing, that would be a different story but at my age I'm just happy to be cruising.
Old 02-04-2009, 10:02 PM
farmerstu's Avatar
farmerstu
farmerstu is offline
I have them on my 07 wg with rhinehart 2into1 and se aircleaner. they work great . (a free flow a.c. doesn't change the way the xieds work.) I see no need for a sert until a cam change or greater mod.
Old 02-04-2009, 10:24 PM
ezriderpgh's Avatar
ezriderpgh
While it is true that a free flow a/c does not change the way the xied's work they only help in closed loop. You are taking a risk running with open exhaust and a/c and no fuel management, the xied's are not helping in open loop. So having them makes no difference when you're cruising down the road.....but i'm no expert on anything, you should check with some pros.
Old 02-05-2009, 01:40 AM
mo-fo-joe's Avatar
mo-fo-joe
mo-fo-joe is offline
I run XIEDS on my 2008 superglide during the summer months, and run my bike without them in the winter because heat is not an issue...I have rush 2.0 slipons and it runs great either way [ stock air breather ]
Old 02-05-2009, 02:32 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
HoggyMtnBreakdown is offline
What's an XiED and can somebody give an example of a product name that fits this category of tuner?
Old 02-05-2009, 07:46 AM
jluvs2ride's Avatar
jluvs2ride
jluvs2ride is offline
Location: Back in the Good Ole USA. South Carolina to be exact.
Closed loop probably accounts for 80% of your riding. I have Rush muffles w/2 inch baffles and a JET Phase II AirStack. Bike ran good w/xieds. Got a SEST Pro, tweaked the VE tables and took the XIEDS off but I think I'm going to put them back on till I can get the bike tuned on a dyno.
The XIEDS are way to easy to plug and play install. They are jumpers with a resister inline that go between the O2 Sensors and the ECM. They recalibrate the output from the O2 sensors to cause the bike to run richer.
Old 02-05-2009, 07:52 AM
Low_Wider's Avatar
Low_Wider
Low_Wider is offline
EZ,
As I understand the Harley ECM it is only during closed loop operation that it drives the A/F ratio to 14.7 where you can get your lean issues. When it goes open loop it's not sure where it's at so it makes some assumptions and makes the A/F ratio lower (not sure exactly how much lower) just to be "safe". So I don't think in this case of pipes and stock A/C it will be an issue.
Quick Reply: Are the XIEDs right for my situation?
