Wand style car wash ok?
Old 02-01-2009 | 01:07 PM
cHarley's Avatar
cHarley
In addition to staying away from the electronics, also avoid high pressure around the axles. Not good for the bearings.
Old 02-01-2009 | 02:26 PM
Trailfndr's Avatar
Trailfndr
If its just light dust and fingerprints, Harley Gloss does a fine job. Spray on, Wipe off. I use it for quick spot cleaning like that all the time. Also when on multiple day rides, I use it each morning to clean up the scoot before the days ride.
Old 02-01-2009 | 03:41 PM
oldairboater's Avatar
oldairboater
The only time I have used any pressure washing on any of my bikes is after running over a Raccoon. Hit him going about 65 mph and he crapped. I had coon crap in the jugs, under the tank, all over me and the bike. It was everywhere. I hit the only constipated raccoon in Texas. The only way I could get most of it off of the bike was to use a pressure washer at a distance. I didn't like washing the bike with a pressure washer and I will not do it again unless I have to. I prefer water hose with no pressure. Non abrasive rags and cleaners.
Old 02-01-2009 | 03:44 PM
PastorTom's Avatar
PastorTom
Do it all the time.Have fer years... take it easy around fork tube seals and axles..
Old 02-01-2009 | 03:50 PM
hogginit's Avatar
hogginit
Have seens more than a few bikes in the dealers for bearing failure or faulty wiring due to corrosion especially electical plugs. Dealers will tell you - no problem with car spray wash- they get the repair work to say nothing of the troubleshooting.
Old 02-01-2009 | 04:20 PM
HD7585's Avatar
HD7585
Just keep the spray away from the electronics and wheel and neck bearings
Old 02-01-2009 | 04:46 PM
conroskie's Avatar
conroskie
I haven't found a better way to clean off the bugs, I fire it up in the morning and putt to the car wash, putt home and blow dry it and wipe it down with pledge.
Old 02-01-2009 | 04:55 PM
BigGdawg's Avatar
BigGdawg
What he and everybody else said.
Old 02-01-2009 | 06:12 PM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
My pressure washer has 4 tips, each with a different pressure. I use the low pressure which mimics a car wash. It also has a soap pickup tube so It gets a good car wash soap.
I rinse it with the same tip and blow it dry with a leaf blower and then spray it with regular Pledge. NOT Lemon pledge because it's acidic.
Our well water is very pure snow-melt from high in the mountains and doesn't spot. The Mr. Clean system is an option if your water tends to spot.
I use Westley's Bleche Wite on whitewalls or blackwalls.
I have an '86 Heritage which still looks almost new after 23 years of my "abuse."
Old 02-01-2009 | 06:19 PM
will2002's Avatar
will2002
Works for me too!
Quick Reply: Wand style car wash ok?
