car tire on a harley
#51
The stock rear tire for the 07 street bob is 160/70/17 which last between 5000-10000 miles.
Iv chec.ked on the smallest 17" tire they make and found it to be the 205/50/17. according to specs the tires are almost the same height.the 205 is about 1 1/2 inches wider than the stock harley tire. my thinking is the 205 being low profile would pull in on each side of the stock rim and not be a problem. im also thinking it should get 20,000 miles or better.
has anyone ever done this. i tryed this on honda vtx 1800 and it worked great.i have spoke rims and also wonder if the stock tube would work.any input from someone whos done this would help
#54
I run a car tire on a Valkyrie I have. Toyo Proxes, hell of a tire. I have over 52k on the tire. Ridden the Dragon 6 times. Pic of tire on Valk with 46k at the time. Got a little feedback from the road at low speed but nothing really to worry about. You get used to it after a couple of weeks. You guys have got my mind whirling again after reading this thread. Man, this tire would look sweet the bike.
#55
Oh no, I have no idea what I'm talking about. I just worked DIRECTLY with Yokohama and Toyo directly for YEARS! I'm also certified to educate tire chains on the history and exactly which tires can and can't do things for both companies, even helped out with the R&D for a specific model of tire for Toyo, and held a very prestigious position in largest wheel and tire distributer in the country, but I haven't put a car tire on a f*cking bike so I have no idea what I'm talking about huh? lmao! Some of the people on here may not have an open knowledge of this, but I can assure you I do.
#56
OK...I bow to your extensive knowledge of car tires. I am sure you have done exhaustive research on the use of a car tire on a bike and have concluded that doing so will end up in catastrophic failure of the tire killing all who dare to go against your knowledge of the subject...Got it. I have seen and dealt with all kinds of technical "experts" throughout my life so I will add you to the list. Just stated what I have seen. I guess my statement still stands. I have seen more MC tires fail on a bike than I have car tires (zero to be exact) but since most run MC tires I guess that is to be expected.
#57
I find it interesting the nay sayer's are as passionate as those in the political section.
I don't get it. If you want to ride on the Darkside then by all means go for it. If not then don't.
It's like those people who make fun of fingerless gloves and chaps. If they don't like them then don't wear them. Making fun of people who do just shows how little class a person has.
#58
No...I got your point. I didnt mean to imply people were ignorant of tires. So you missed my point. If you conducted an experiment on the use of a car tire on a MC and determined based on data that it was dangerous, your good to go. This would imply that you put one on a MC and conducted test and was able to document your results. I personnaly would love to see it. If you are telling me you have never looked into the subject, then you are basing your opinion on your knowledge of tires alone. Well, then it is your opinion educated or not. If a car tire fits on a rim (not forcing it), why wouldnt it work for normal applications. MC tires and car tires fail either can be catostrophic on a MC. High speed MC racing tires are different than normal cruiser tires. I am not trying to talk someone into this practice. I do know of people that have done it for decades with absolutely no problem and in most cases vast improvements in some areas (longevity, traction in wet conditions, etc.). If I hurt your feelings about your knowledge of tires my apologies. I am absolutely positive that MC tires could be made to last longer and perform better but there is no financial incentive to do so.
You totally missed my point and completely and utterly overexaggerated your point. My point was that you shouldn't assume someone doesn't have any knowledge of a subject just because they have not personally done something. A lot of things can be fairly well figured out in theory, however there is are a lot of things that would need additional "field research". The comment was made that "people who haven't done this know nothing". Granted that's paraphrasing it, but more or less that's what was said. I'm just stating that I do have quite a bit of knowledge about tires and how they work. I still stand by my "it's not a good idea" standpoint, but if people want to try it by all means good luck. Sometimes necessity is the mother of all inventions, but on the flip side of the coin things can still go badly. I just hate seeing a fellow biker downed, for whatever reason. You know what I mean?
#59
#60
