UPDATED - How To: Diagnostic Trouble Codes (DTC's)
Old 09-21-2009, 07:36 PM
cHarley's Avatar
cHarley
cHarley is offline
Originally Posted by genedjr
I have this exact thing. And after searching I see that this means the diagnostic code 1 is clear.
Should I assump that if no codes are sent that you don't see the 'diag' initial screen on the speedo?
...gene
Originally Posted by mater r-130
When i push the button and then turn on the switch the speedo does nothing, no sweeping action. The word diag does not appear?. what i do get is do1clr and when you push the button it goes to the samething do2clr and so on to do10clr, I push it one more time and it says cal 03. What does this mean?.
Sorry, but the above DTC list and procedure applies to newer model ICM/ECM bikes, starting in I believe 2004.
Old 11-08-2009, 09:55 AM
sahara38's Avatar
sahara38
sahara38 is offline
Thumbs up
cHarley...thanks for the info here. I've got the pdf saved to my computer for future reference. Very helpful.
Old 03-08-2010, 05:11 PM
RoadKing904's Avatar
RoadKing904
RoadKing904 is offline
I have a 99 FLHRCI and have the older diagnostic codes and the last position is Cal 03 - does anyone have the translation of the 10 diagnostic codes?
Appreciate everyone's input.
Old 03-18-2010, 01:10 PM
wideglidewy's Avatar
wideglidewy
wideglidewy is offline
Hi - gread thread. I have a dead '04 FXDWG - will turn over but no spark. Suspected bad ICM. Ran diagnostic and the code was "no rsp" - does this mean a short, dead ICM, or both? Thanks in advance.
Old 03-18-2010, 01:29 PM
cHarley's Avatar
cHarley
cHarley is offline
You might want to thoroughly reread the OP to make sure you are checking all groups of codes.
This is in the OP instructions:
"On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected."
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure."
Old 03-22-2010, 12:52 PM
clarkchriston's Avatar
clarkchriston
clarkchriston is offline
Thanks for the info. Hopefully I will never need it but we all know that's highly unlikely.
Old 03-22-2010, 02:39 PM
FXDXTSport's Avatar
FXDXTSport
FXDXTSport is offline
Three pages in and I find out it doesen't apply to my bike What a useless post JUST KIDDING I think this might be the most informative post I've seen on this forum if you have an 04 to 08 bike.
Old 03-26-2010, 06:54 PM
masterblaster's Avatar
masterblaster
masterblaster is offline
Thanks Charley, I just figured out my ECU, a newley installed Thundermax is not responding, wasted a whole day trying to figure why the dam computer would not link, even went and bought a different usb sserial adaptor.
Great thread.
Old 03-27-2010, 07:02 AM
silverwolf79's Avatar
silverwolf79
silverwolf79 is offline
Thanks Guys , excellent post !
Old 04-30-2010, 10:42 AM
Just Plain Cody's Avatar
Just Plain Cody
Just Plain Cody is offline
What does it mean when the speedo digital display says "no CAL" and Speedo does Not go in to diag mode at all? This is on an 07 XL1200C. This code ('no CAL') is not mentioned in this thread.
Quick Reply: UPDATED - How To: Diagnostic Trouble Codes (DTC's)
