oil temp vs pressure?
I'm going on a road trip to key west in jan and hear there is crazy traffic.I run synthetic oil in my bike but would like a gauge to keep track of what's going on.I like the look of the oil pressure gauge on the rocker box but was wondering what people thought of pressure vs temp gauge?In my understanding the pressure will drop as the temp goes up so both ways should tell me what I need to know. Right??
I would get an oil pressure guage because it will tell you if you have a lubrication issue. Oil viscosity will thin out as temperature increases so there will be some nominal drop in oil pressure. But a TC engine uses a high volume low pressure system. While oil temp is important the oil pressure guage will alert you to a drop in oil pressure that would indicate a problem of sorts.
SYn oil is good usually to 300*F + so watching it get hot is information after the fact. Kinda like "gee my oil is really hot" versus "Holy $hit I don't have any oil pressure"
Ditto on what was said above, temp will only tell you if its hot or not. Its not going to tell you if you have pressure so you wouldn't know that your oil pump went out until you looked down and saw your temp had gone thru the roof and maybe too late..
Never had a temp gauge, BUT ALL my scoots get a pressure gauge. It's located at the rear and top of the 'kidney' cover, pointed right at me face when I'm riding.
This one is a bit more difficult to see, but in the same location.
You only need to have a chunk of junk get caught in the oil pump once, and shear the key off, to learn to put on a gauge, ALL THE TIME.
pressure gauge is best, but if you listen the bike will tell you if it has pressure or if over heating(knocking sounds if you lose oil pressure and pinging or valve noise is a good sign its running to hot)please keep in mind if you hear knocking it maybe to late. most people with gauges don't think the gauge is correct and ride til the noise start any way. just remember if you get a gauge and a low pressure reading stop and turn it off asap if it shows no pressure. also stay away from the harley unit(i purchased one)cheep plastic hose to run oil up into gauge(i think it will melt) i have the harley unit, looking to get the steel braded arlen ness hose or some other brand hose.
oil guages
I would go with the pressure guage. Since you are running syn oil. I run syn oil here in las vegas and never had a problem and it can get mighty hot here in the summer sitting in traffic.
AND that's at the oil pump. If ya got 20 at speed, JUST
