Tire pressure for Avon Venoms?
Old 12-11-2008, 09:34 PM
jdc48160's Avatar
jdc48160
jdc48160 is offline
Originally Posted by cHarley
The same tire that I run on the rear of my Sporty also is the specified tire for a Goldwing. Under your theory, my tire should be run at the same pressure as the one on a Wing loaded with baggage and running 2up? I think not.
What's the max pressure specified on the tire you're running? And, what brand/model of tire is it?
Old 12-11-2008, 09:48 PM
anubisss's Avatar
anubisss
anubisss is offline
Originally Posted by 7/11 The Crapshooter
Careful hear, this is for maximum weight when at cold temperature. If you are talking about the Venom X, they like pressure and are resistant to cupping if you keep the tires up in the 40-42 psi range. Seems a bit high for those who are used to running Dunlops or Metzeler but this is the only way you will keep them from cupping and they will give you some solid miles too.
This is where I run my tires now (dunlops) as I want maximun wear out of them. I believe the Avon's are softer. Thanks for all the answers and I'll check the Avon fitment guide...
Old 12-11-2008, 09:58 PM
7/11 The Crapshooter's Avatar
7/11 The Crapshooter is offline
Correct, they are softer but there grip like glue. They also offer a great ride.
Old 12-11-2008, 10:19 PM
bikergeoff's Avatar
bikergeoff
bikergeoff is offline
I run the Venoms on my Ultra 39 psi on the front, 42 in the rear. Great tires.
Old 12-11-2008, 10:22 PM
ChromeJunkie's Avatar
ChromeJunkie
ChromeJunkie is online now
Received 4,226 Likes on 1,841 Posts
I am on my 3rd set of Avons (rear). The first one I ran 40 lbs as per the shop that sold me the tire and got right at 10K. J&P has a chart for Avons in their catalog and says 44 psi for solo 170 lb rider/w no luggage. and 46 psi for light 2 up. I am about 250 lbs and ran 45-46 psi in my 2nd Avon and got right at 14K on that tire. Avon used to have a pressure chart on their website, but I can't find it. 40 psi is recommended for the front tire.
Old 12-11-2008, 10:28 PM
anubisss's Avatar
anubisss
anubisss is offline
You answered my next question. Thanks.
Craig4711a
03-23-2018 03:13 PM
DylanD15
06-16-2017 07:29 AM
pretz
03-09-2015 10:09 AM
Sprinter7x
2014-2023 Touring Models
05-10-2014 09:40 PM
jajaxxon
01-25-2012 11:29 AM
Quick Reply: Tire pressure for Avon Venoms?
