Gas additive in cold weather ?
Probably a really stupid question but I am planning on riding all winter if possible. Is it necessary to put an additive like dry gas in the tank when the temp gets below freezing ? When I ride to work the bike sits outside for about 9-10 hrs and I quess I am concerned if there is any moisture in the gas it will freeze and give me problems starting and running.
Bikes are different than cars, because you fill up more often, so the the fuel gets cycled. Less chance for moisture to build up. Plus there's 10% ethenol in most of today's fuels, which helps with moisture. If you want to be sure, add a few capfulls of SEAFOAM at each or every other fill up.
Agree with the moisture concern in cold, damp regions.
A couple of cap full of seafoam is a good idea if you live in a cold weather area.
And by the way,
Welcome from the central coast of sunny California,
Krusr
And by the way,
Krusr
If you're going to ride your bike, I wouldn't add anything to the gas. In fact, depending on where you live, many winter blends (gas) are already treated with additives to prevent freeze up, moisture, etc. This is why you don't see people adding Heet to gas anymore.
Not necessary with a motorcycle. However, in freezing temps it is sometimes advisable to add one 12oz additive to the rider.....at least it was before I quit drinkin........
