Dyna Beads
Old 10-20-2008, 06:34 PM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,664 Likes on 946 Posts
I've been using them for years and love 'em. Actually last year I switched over to high density airsoft pellets. I get a big jug of them for $5 at Walmart. 200 or so of the pellets in a 16 inch tire works great. Only downside to the airsofts are you cant use them in a tube tire but you can use the dynabeads.
Old 10-20-2008, 08:00 PM
kwoozn's Avatar
kwoozn
kwoozn is offline
Read about them last week.
Interesting...
http://www.innovativebalancing.com/
Old 11-13-2008, 04:20 AM
UltraDuke's Avatar
UltraDuke
UltraDuke is offline
mmmmm dyna beads. good stuff. just installed em. tookem for a run. smooth ride.
Old 11-13-2008, 04:51 AM
Roadjunkie1's Avatar
Roadjunkie1
Roadjunkie1 is offline
Originally Posted by SloChicken
are those the things some girls shove up their ***???
If you provided a picture, might be able to answer correctly.
Old 11-13-2008, 04:53 AM
Roadjunkie1
BTW, for the guy that changes his own tires. Dyna beads rock!
Roadjunkie1
And another reason why tubed tires suk.
Old 11-13-2008, 05:57 AM
klap's Avatar
klap
klap is offline
they work well in tube or tubeless..no ugly weights on the outside..try 'em
http://www.innovativebalancing.com/motorcycle.htm
Old 11-14-2008, 12:17 PM
Beertapper's Avatar
Beertapper
Beertapper is offline
Remember you can not use Slime or Fix-A-Flat after this. You'll have a gooey ball of beads floating in your tire.
Old 11-14-2008, 12:23 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
Did you guys that recently tried them remove the wheel weights before testing?
Old 11-14-2008, 12:27 PM
UltraDuke's Avatar
UltraDuke
you can use your slime or fix a flat. of course if you have use either you will be replacing the wheel anyways. so in an emergency i am putting that sheet in.
Quick Reply: Dyna Beads
