Rear brake problems
Rear brake problems
Hi,
I have a 2005 883 Sportster Low and recently the rear brake is giving me problems. It all started when I replaced the brake light switch because the brake light was not coming on when I depressed the foot brake pedal.
I bled the brake line after replacing the switch thinking this would solve the problem, It did not.
After bleeding the brake line and adjusting the pedal height I had brakes. After it sat over night I had no rear brake.
I am thinking the master cylinder is suspect because when I press hard on the pedal it fades slowly.
Anyone ever experience this problem?
Faspony
Faspony
Hi Marksman,
There is no leaking going on and that's why I am thinking it's the master cyl not holding pressure. I have bled the brakes at least 5 times and still little or no rear brake.
Thanks
Thanks
Beefcake
11-23-2005 01:31 PM
