Who Checks the oil in their primary?
Old 03-30-2006 | 10:50 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default Who Checks the oil in their primary?
I'm just curious, how many people actually pull the cover off and check the primary oil? Seems to me if you go to all that trouble you should change it.
Old 03-31-2006 | 12:02 AM
06dynablack's Avatar
06dynablack
Default RE: Who Checks the oil in their primary?
I used to check mine every now and then only because it seeped.
Old 03-31-2006 | 12:08 AM
KBFXDLI's Avatar
KBFXDLI
Yeah, well that makes sense if the oil was getting out. But I have read several threads one here and two somewhere else that said to check it every couple of thousand miles. Just didn't make sense to me unless you have a leak otherwise wouldn't HD put a dipstick in the primary?
Old 03-31-2006 | 12:17 AM
UncleMike's Avatar
UncleMike
I like to check mine every so often, the new gaskets can be reused if you're careful ( even though they say don't reuse) never had a problem reusing them 1,2, even 3 times. Hey it's only 5 screws and something to do on rainy days.
Old 03-31-2006 | 12:18 AM
UncleMike's Avatar
UncleMike
Sorry, don't know why it posted twice. Had some wierd stuff pop up and must have hit the OK twice..
Old 03-31-2006 | 01:21 AM
nmfxstc's Avatar
nmfxstc
Primary juice? We have that? Which side is it on? Guess I don't check it...it shifts, it runs....it's good!
Old 03-31-2006 | 01:27 AM
superdog48's Avatar
superdog48
KB, I agree with you and others. If you have to check the primary I would change itor if you have a seeping I would find out where it's leaking.
Old 03-31-2006 | 01:31 AM
RED E GLIDE's Avatar
RED E GLIDE
I change mine every 2500 miles with 32 onces and monitor my floor for leaks (none yet).
Old 03-31-2006 | 01:50 AM
BigJohn's Avatar
BigJohn
If I dont see it on the ground, gotta assume its stil in there.
Old 03-31-2006 | 02:01 AM
HDWG's Avatar
HDWG
I am going to change mine this weekend, I have a little leak at the inspection cover, either the gasket is backwards, it is too full, needs a new gasket or, I guess I need to try flipping the cover over.........it is really disruptive to ahave that damn little leak[:@]
Quick Reply: Who Checks the oil in their primary?
