Anyone had their windshield cut down?
Old 09-17-2008, 09:21 PM
dugan's Avatar
dugan
dugan is offline
Default Anyone had their windshield cut down?
I just got the Nostalgic Standard Windshield and find it a couple of inches to tall. The Low Profile would probably be to short. Maybe have a glass cutter cut it down, if they can do it and make it look professional. For those of you that have had it cut, is it a noticeable quality wise? Any advice or tips? And no I don't trust myself to do it.
Old 09-17-2008, 09:30 PM
Comfortably Numb's Avatar
Comfortably Numb
Comfortably Numb is offline
Default I cut my own..
A lot of folks here have cut down their own, but I can understand if you don't want to tackle it yourself.
Better still, just go get a Clearview with a recurve. Mine works better than my stocker cut down 2 inches, and it's another inch shorter again. (RK Classic)
CN
Old 09-17-2008, 09:31 PM
Streets of Fire's Avatar
Streets of Fire
Streets of Fire is offline
I'm looking to do the same.. looking for input as well
Old 09-17-2008, 09:41 PM
bluffalobob's Avatar
bluffalobob
bluffalobob is offline
I cut the old one on my Fatboy, easy as pie. As long as your comfortable with woodworking tools, you should not have a problem.
First, I traced the top onto a piece of cardboard for a template. Now, move it down a couple of inches. You'll notice it isn't quite wide enough, due to the taper of the windshield. Just slide the template to the edge, and trace the pattern with a grease pencil to the center. Slide the template to the other edge, and trace it to the middle, and smooth out the arch a bit.
I put some painters tape on the windshield to keep from scratching it. I then put an old rug on the workbench, and got out the jigsaw with a new blade, and started cuting. Go slow so you don't melt the plastic. Once you finish cutting it, sand it smooth with a sander, take off the tape, and you're done. You can even wet a rag with acetone, and smooth the edge to a mirror surface if you want.
No one could believe I did it myself. There's a local guy recommended by the dealer who cuts them with a router, but he wanted $60. I figured I'd just buy a new windshield for that, and sell the old one. Glad I didn't, it only took about 30 minutes, and it was perfect!
Old 09-17-2008, 09:46 PM
Comfortably Numb
Default Yup..
Jigsaw here too. I held it, a friend cut it. I left way too much to trim off, so be real accurate with your line so you're close to what you want in the end.
I used a flat file to finish it off. You can't distinguish the finished edge from the original.
CN
Old 09-17-2008, 09:58 PM
aviator's Avatar
aviator
aviator is offline
I took the easy way out. I had a glass company do it for $20.00 I marked it, they cut and polished the edges.
Old 09-17-2008, 10:07 PM
kruzin's Avatar
kruzin
kruzin is offline
I cut mine. Taped the windshield where to cut, traced the new edge with a template then cut with a band saw. Finished up with my sander and you could never tell it was done. Really easy to do.
Old 09-17-2008, 10:29 PM
Xguy's Avatar
Xguy
Xguy is offline
Old 09-17-2008, 10:39 PM
ownasofttail's Avatar
ownasofttail
ownasofttail is offline
Most glass Companys will do it but you will have to mark how much you want cut.most will do it while you wait.Good luck Send me a pic with it on the Fatboy.
Old 09-17-2008, 11:03 PM
itileman's Avatar
itileman
itileman is offline
Had a glass company cut one to 11" and the other to 17"
Professional job - worth the money.
17" shown:
Quick Reply: Anyone had their windshield cut down?
