Prescription Riding Glasses?
I just got my second order for prescription riding glasses and in both cases the glasses realy distorted my vision. Has anyone else had this problem and know of some frames that won't distort my vision, and where can I get them? Thanks.
My optometrist made prescription lens for Wiley-X frames with no distortion. Made both clear and tinted, as the lens are removable from the frames. Really liked them. I've since had lasik, which is even better.
Received 1,313 Likes
Bought a pair of clear and tinted down at Biketoberfest three years ago. The inside comes out held by small magnets in the frame and you have your lenses put in those. You can switch them from one pair to the other. They cost me $15.00 for the two pair and the lenses I had made here at home for $50.00. Never noticed any distortion but I don't see that well anymore!
The only times I've known of distortion with script lenses are when either the doc gave a bad script or the eyeglass manufactor goofed. This year I got two pair of glasses. On trans, bi-focal from eyeland. The other ,I took eyelands script to sears and got a pair of rec specs ,to ride with.
A big difference in clarity. The sears specs are like looking through a good nikon. I got transition, no line bifocals; they are not safety glass. Enjoy them and would rear them as my regular daily.
I just got my first pair of prescription sun/riding glasses. I got them from www.sportrx.com. I got a pair of Panoptyx Diablo's with a removable eye seal. I had to get the RX adaptors because of my prescription, but I get no distortion through the lenses. They specialize in prescriptions on wrap-around glasses. And their prices are very competitive. I really like the glasses.
My experience with eyeglasses is that if you have distortion, the RX is incorrect. Your local optician should be able to tell you the prescription by checking the lenses.
Good luck!
Good luck!
if the prescription is ok(good correction) and the optician did a good job
there couldn't be distortion.
maybe u have to get the glasses back to the optometrist fer a check
