1340cc motor seems doggy- spits/sputters
Old 09-11-2008 | 12:26 PM
mark mesi's Avatar
mark mesi
Default 1340cc motor seems doggy- spits/sputters
I recently purchased a 99 FXR with a 1340 cc motor in it. The motor has the stage 1 Screaming Eagle kit with the carb , pipes and differant cam. As I'm going down the road, if i keep the "R"'s up around 2700-2800 in any gear, it runs fine. When i go to shift to the next gear and the "R"'s drop down to 2000-2200 it sputters and spits if I need to keep it there awhile to keep me from going to fast over the speed limit. The reason for going to the next gear is I don't always want it running that high all the time in the same one. To get rid of the sputtering, I slow down back to next lowest gear and it is fine.
The second issue is as i go to get on it through the gears, I normally shift right at around 3000 where it seems to get up and go good. It seems if I drag it out near 3200-3400 it wants to dive down like it's starving for fuel? What is a good rpm to shift this bike? I'm afraid to take it anywhere near a shift of 4000 for fear of blowing the motor up??? What do you think?
Old 09-11-2008 | 06:30 PM
Dorkman's Avatar
Dorkman
Could be the carb still isn't jetted properly. Read the plugs. If its jetted properly the plugs should be a tan or rust powder color. A light glassy deposit, worn electrodes, indicate a lean mixture and overheating. A sooty black deposit indicates too rich a mixture. Timing or valves not seated could be an issue as well. With that amount of work it takes a bit of adjustment to get it running right. Good idea to get it looked at.
Old 09-11-2008 | 10:01 PM
oldairboater's Avatar
oldairboater
I agree with reading the plugs and possibly rejetting. Only thing I wonder is when did it start?
Old 09-11-2008 | 10:16 PM
High Gear's Avatar
High Gear
Has the bike been sitting quite a while ( gummed carbs ) ?
Try a strong mix of Seafoam in the gas tank .
This has worked well for me before .
Old 09-11-2008 | 11:39 PM
Da Gumpmeister's Avatar
Da Gumpmeister
But a can of Seafoam as posted. 1/4 can for a tankful.
Once you have that done, start jetting.
Old 09-11-2008 | 11:45 PM
bagman1's Avatar
bagman1
+1 sounds like hi speed jet, Id think if it were gunky fuel it would run the chits across the rpm band. I thought the last FXR made was in 95. Any case Id like to have a project bike like that.
Old 09-12-2008 | 09:44 AM
mjunk1's Avatar
mjunk1
Wouldn't it be the low speed jet? I thought that was the one that worked when you were just "cruising" at minimal throttle and the main jet flow only kicked in when you were getting on it. I might be confused.
Old 09-12-2008 | 09:48 AM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
What the heck is seafoam? Where do you find it? Will it clean out the carb on a 4 cycle Briggs lawnmower that's been sitting a couple of years?
Old 09-12-2008 | 09:57 AM
brenn's Avatar
brenn
I have the same with my 97 XL 1200. I recently bought it with Screaming Eagle air cleaner and straight drag pipes and that's all I know about what's been done, but my best guess is that the carb isn't set up/adjusted to work with the pipes. I'm going to start with some actual Harley pipes with mufflers and work on the carb after that.
Old 09-12-2008 | 04:07 PM
mark mesi's Avatar
mark mesi
They brought back the FXR-3 in 99 with a limited production number made. Mine was one of 64 made.
