1340cc motor seems doggy- spits/sputters
I've had the bike about 5 weeks taking it right from the owner who rode it on a regular basis. I only run the best gas available. Maybe the other owner never brought it up towards the 4000 rpm range to feel the bike fall off in power. I see or hear a lot of harley guys shift rather quicky rather than take each gear a little longer. maybe it's just best to take it in and have it done right by a trained professional and eat the cost???
Could be the carb still isn't jetted properly. Read the plugs. If its jetted properly the plugs should be a tan or rust powder color. A light glassy deposit, worn electrodes, indicate a lean mixture and overheating. A sooty black deposit indicates too rich a mixture. Timing or valves not seated could be an issue as well. With that amount of work it takes a bit of adjustment to get it running right. Good idea to get it looked at.
